OK, here's some pics of my Upper Rear Control Arms and Upper Rear Traction Rods installed. I had to do it to increase my compression travel. When I found out that I only had 1" of compression travel with my stock arms it scared me. Can you imagine taking a corner at high speeds and hitting a bump with only 1" of compression travel? The install was straight forward with only one small problem. The inserts at the ends of the Upper Control arms were placed at the wrong ends. I had to pop out the inserts and switch ends. The ones at the wheel are larger 19mm bolt head, and the ones at the body are 17mm. Wasn't the easiest thing but I got it done.
This is a long version of the corny imovie preview. I was battling having to much traction all day even with a square wheel set up. This is with the full rear MAX suspension. I can't wait to get more power so I can put up a real smoke storm.
