Sun Mar 11 2012, 04:42am
Registered Member #5
Great stuff! Very nice work! Too bad that nobody makes press in pillow balls for all the joints(instead of urethane)...that made a pretty big difference for my old FC suspention...fact that u dont have to rely on bushings twisting, stressing and maintenacing, pillow balls gives u more of the direct suspention travel I think...and let the coilover do all the wrk for it. anyway what U've done for ur car is super awsome!
[ Edited Sun Mar 11 2012, 04:45am ]
rwdanthony
Sat Mar 17 2012, 09:45pm
Registered Member #1196
no doubt the pillow balls would make a vast difference. its a shame really, but the poly urethane will do for me. i appreciate both your help and your kind words martin!
rwdanthony
Sat Mar 17 2012, 09:50pm
the wet weather has delayed me from finishing my electrical but heres some updates.
made the harness for all my engine management and vital monitors which connects to my engine harness with a single 14-pin connector
last three extensions, just waiting for clear skies so i can solder them onto the engine harness.
center console is all together!
currently midway through my abs delete process, and picked this up
oil filter relocation with my oil temp and pressure sensors
[ Edited Thu Mar 22 2012, 04:20am ]
Mon Mar 19 2012, 06:53pm
nice
Wed Mar 21 2012, 05:39am
is that a max oil filter relocate kit ? looks like it. if so good to know it works on toyotas as well!!
rwdanthony
Thu Mar 22 2012, 03:52am
nice
thanks dan!
Hollywood wrote ...
it sure is, all you need to do is swap out one of the union studs with another one that works with fram3614 size filters. ka/sr filters are much smaller than the 3614 size. i just used the oem union off the n/a motor and everything mates up. i just need lines now.
updates:
no more abs!
i decided not to "T" off the abs brake lines, rather remove all of it together, and just make new lines like a non-abs car. im using these napa polymer brake lines, this stuff is great and cheap. the quality is just like oem!
To do list:
1. front brake lines + “T” fitting
2. rear ss brake lines
3. bleed brakes
4. wrap and re-tuck body harness
5. install front sway bar end links
6. clamp extended harness
7. clean and complete fuse box
8. shave rhd wheel well and hammer up
9. paint inner well
10. paint engine bay
[ Edited Thu Mar 22 2012, 03:53am ]
rwdanthony
Sat Mar 24 2012, 04:15am
I decided to put the subframe back under the car as the subframe bushings are nearing completion! With it butt against the body, the front side of the RUCA just kisses the body, I could have gotten away by just hammering it or notching it, but I decided to just grind it down, and follow the above contour.
stock:
grinded:
rubberized underbody + black paint:
the resulting fitment:
i just love how clean this is!
jimking / suprasport v3 short shifter, this thing is rad, the throw between gears are greatly reduced!
stock shifter, but it's height has been shortened about 1.5"
3rd gear:
neutral:
4th gear:
jim king / suprasport v3 short shifter
3rd gear:
neutral:
4th gear:
finished up my aero today as well
rwdanthony
Sun Mar 25 2012, 11:18pm
fuel pressure sensor installed on fuel delivery line:
oil filter relocation mounted, just need to measure lines and what angle of fittings:
all systems go, except for the head unit
i wont be able to accomplish everything that i wanted to do, but for now the priority is to get her back on the road.
o.g.darkdrifter
Mon Mar 26 2012, 01:50am
Registered Member #580
Your car is cool. Makes me really want a garage.
rwdanthony
Mon Mar 26 2012, 03:01am
i dont have a garage haha, or atleast one i work in.
