MAX 100% 304 Stainless FLEX COBRA, it spits hot fire! << Previous thread | Next thread >>
Thu May 07 2009, 08:52pm
Registered Member #5
Im stoked!
Sideways_In_SD
Sat May 09 2009, 12:21am
Registered Member #6
DAAAAAAAAAAAMMMMMMMMMMMMMNNN!!!
I JUST bought a turbo outlet off a guy 2 weeks ago SOB!
Shit looks fucking awesome guys!!
Marty, you're turning into the TIG-inator!!!!!
Tue May 12 2009, 12:40am
sexy
Vertical flex
Turbine/wastegate Divider
Smooth segmented bend
Slotted 5th hole for T25 and T28 turbo
We can install a 2nd O2 bung wherever you like.
[ Edited Tue May 12 2009, 12:56am ]
Marcus
Tue May 12 2009, 03:29am
Registered Member #439
wow looks so sick.
got any extra material? i wanna have some dual straight pipes made outta this stuff!!
Tue May 12 2009, 05:50pm
no but im about to reorder material, so I can get more for your project if you want = )
Tue Jun 09 2009, 11:15pm
here is a custom cobra we built for a customer requiring 2" vertical extension and wideband bung
Wed Jun 10 2009, 07:56pm
without dump elbow for top mount turbo application
Wed Aug 12 2009, 06:14pm
with and without separator (s15 turbo has this built in)
[ Edited Wed Aug 12 2009, 06:18pm ]
Wed Aug 12 2009, 07:24pm
picture showing the thickness difference between a typical aftermarket 3" flange and ours:
Wed Dec 30 2009, 08:26pm
picture showing some oxidation inside the pipe, this is there because we dont back purge to keep the cost under control but if you are anal retentive about how smooth the inside of the pipe is you can run a flexible ball hone through it.
