nope im stupid got excited and posted that cuz my shit tore up the other night. soo now im on home made delrin inserts till these are back in stock. ugh
Ok so I am curious about something. Why do the s chassis risers have the big countersink in them instead of just being flat like the genesis ones. I had a machinist friend cut me some nice big washers to use because using the factory hardware required spacing the nut out with washers and I just dont want to do that. is there something I am missing?
Usually we put the OEM large washer back on there, or in the case of S15 its the OEM subframe brace that has two circular mounts that fits right up in that space.
Ya I put the oem large washer back on and it actually hit the taper on the stud before it came up tight on the nut and i also ran out of threads on the nut. maybe a slight difference in the studs? also do you see any issues with using a large washer over the top of the bushing. I had 2.5 inch od 1/4 thick washers made up just to kinda clean it up.
