I have few questions.. If you don't mind me asking Okay for the pics you have posted I wanted to get it right. The first 3 are the 2-piece rotors and the last 3 are the 1 pieces rotors. Right?? Also you said the 1 piece would be cheaper? I didn't see any different on your online shop.
Also just to get this straight. For the rotors in your pics those look like Z32 calipers on there. What's going on there?
I was also wondering what's the rotor made of?
Last thing. I know somewhere it said that I need a 17+ rim to fit. Is there a offset to that? Or what? Thanks!
you need to be very careful about selecting the correct caliper, otherwise they will not fit our brake rotors.
Our brake rotors and brackets are for Z32 30mm calipers. (which are like S15 calipers and R32GTST kouki and S15, and S14 kouki JDM brakes. (these had a 280mm rotor originally) Which means when they are adapted to the 330mm rotor we have the bracket makes the caliper sit properly although not with 100% contact being that they were originally designed for a smaller rotor.
However there are many nissan calipers that our rotors are not compatible with like anything that is not 30mm and anything that is 30mm but originally had a larger rotor like R33 GTS, R34 which had a 296 or 310mm rotor originally which means when you combine it with our rotor bracket made for the Z32 type it sits too high because of the length of the mounting arms on these larger disc calipers.
This may be a silly question - but I'd genuinely like to know if these rotors are compatible with the FC?
I understand that the S13's share the same bolt pattern, and there may be technical knowledge I'm unaware of - but I don't see any compatibility issues.
Again, I'm looking for someone to point out the incompatibility, so any information/advice would be greatly appreciated.
