I think its -10 if my memory serves...march it into Earls to make sure everything lines up proper.
VYKTR wrote ...
Hey Dan do you have pics or diagrams of how we would install the oil cooler kit. Something like the Breather tank diagram, this would be helpful. Thanks.
dont have one... If its just the oil filter then the 2 lines just go paralell from the engile block apdapter to the oil filter adapter, but if you put the cooler in the mix you need a third line because there is 1 line going from the engine block apdapter to the filter adapter, line 2 going from the oil filter adapter to the oil cooler and the line 3 goes from the cooler back to the engine block adapter.
Ok so -10. Oh, and i figured that's kinda what i had to do, but still looking into more info. If it helps anyone there is this tread on Zilvia about coolers, Ill post up my setup there as soon as i get everything sorted out. Thanx Dan
