Hey did you guys ever end up making this - or have the ability to make them? I want some of these and your bad ass multi level wheel spacers immediately!
I have lost some motivation to make that part because we are getting 55 degrees of steering angle center to lock without over centering the tie rod when using out Super angle kit mounted in an offset position. Since over centering only happens when you increase the angle, and our angle kit does not cause over centering it seems that the logical solution would be to use our angle mod to cure the source of the problem instead of the symptom.
This would be a good alternative to cutting the cradle and movIng the rack mounting ports forward. Well for those that don't want to cut theres up. Make them out of delrin. I like where your heads at bro.
Maybe you guys should be offering a normal solid bushing as opposed to an eccentric one. I was looking into getting the yanack bushings, but 150 is way too steep for a tiny piece of metal. Not to mention there really is no supplier in the states for metal rack bushings, so you guys would get all the sales=$$$.
Steering Rack Eccentric Bushing parts in production.
~ Price is $50 with free shipping world wide around the end of February ~ Production parts will be anodized gold aluminum ~ Prevents over centering of tie rod and knuckle to prevent heavy steering at lock ~ Takes ackerman curve from digressive to progressive difference while decreasing overall ackerman
such a good idea for a pbm product. how much correction are they gonna offer.? i actually cut and re-welded my crossmember to move the rack forward about 7/8" but didnt move it up. this would be way easier for most ppl simple unbolt and bolt. gotta love pbm!!!
