i just bought a super street Mag(april2010) ... and there is and article on your super spacer's !!!! props to you guys ... i'm waiting for them to be release for buying some !!!!!
any updates on these bad boys? also, im thinking, with just the 15mm's, i think people with 5 lug universal wheels or wheels that dont have spacing on the wheel pad in between the bolt holes will have clearance issues with the studs on the hub (the studs will stick out past the spacer) only way around that is to cut the wheel studs on the hub shorter to clear the wheels
Update is there is some getting air freighted to hold us over till we see the ocean shipment late may. If the studs are a problem, they just have to be cut. The ideal wheel is the one with big spaces between studs, or one pattern with 8 holes.
