ZenkiGuy
Thu Aug 26 2010, 10:07pm
Registered Member #784
Hey guys. I'm sure this has already been asked many times. But, I should be installing mycoils in a a couple of weeks. And, I just wanted to get some good opinions on what I should set my coils on for a daily driving setup.
Thanks
Thu Aug 26 2010, 10:13pm
I think everyone just sets them on full soft for DD
and if that is not gentle enough for your rear end, you can buy 6 KG springs for $60.
ZenkiGuy
Fri Aug 27 2010, 04:04am
I hope it is ..I mean, I drive pretty hard even on a daily basis so I'll find out soon enough.
Thanks Dan,
Jonathan
ZenkiGuy
Fri Aug 27 2010, 04:08am
Also, not only stiffness, but opinions on camber/toe setups.
Thanks again
Gary.Suk
Fri Aug 27 2010, 08:24am
Registered Member #824
0 toe all around, 1-2deg front camber, 0-1deg rear camber should be pretty good.
Fri Aug 27 2010, 05:07pm
yeah for daily thats a good alignment. bad toe kills tires faster than camber.
Fri Aug 27 2010, 11:10pm
thats the alignment I have on my daily
comatoseghost
Mon Aug 30 2010, 02:41pm
Registered Member #709
Just realized it doesn't specify, so to clarify, that is negative degrees of camber? Not positive?
Gary.Suk
Mon Aug 30 2010, 06:48pm
Yeah it's neg, never posi lol
ZenkiGuy
Tue Aug 31 2010, 02:59am
^ exactly lol..Thanks for all the tips. Because, I definitely don't want to have bad tire wear, but at the same time, I want a good setup. If that makes any sense.
