2012 Hand Brake SLC New design, More choices, Lower price, ala carte components
Isn't progress great? The 2011 model that included a foam grip and in line cylinder was $220 and If you get the 2012 assembly, MAX grip, and the in line cylinder its only $140 now, an $80 savings.
The earls ss lines kit was $130 and our ss lines kit that will be released in march is $70, a $60 savings.
Thats a total of $140 off, sorry no price match refund on last years model, damn!
MAX SLC Hydraulic Hand Brake Assembly ~ Super Light Compact Laser cut steel housing ~ black powder coat finish ~ 7/8" D x 13" L tubular handle with adjustable friction base fits BMX/MTB/moto grips ~ CNC aluminum clevis with gold anodized finish ~ Bump stop, cylinder hardware included ~ Weld on installation requires tranny tunnel reinforcement ~ Only $55 ~ IN STOCK NOW
MAX Helix Grip ~ Aluminum triple helix tube ~ CNC end cap ~ 5 Annodized colors, polished aluminum, and copper plated finish ~ Laser Logo ~ Diamond pattern non slip rubber grip ~ Only $25 ~ IN STOCK NOW
Wilwood in-line Compact Master Cylinder ~ 3/4" bore for short handle stroke ~ Part no. 260-6089 pictured above ~ For use with single rear calipers and OEM brake system ~ For use with our stainless steel braided lines and fittings kit ~ $60 ~ IN STOCK NOW
Wilwood Independent Reservoir Master Cylinder ~ For use with our dual rear caliper drop knuckle ~ For Formula D spec independent hand brake systems with dedicated rear hand brake calipers ~ Model no. 260-10372 ~ 3/4" bore for short handle stroke ~ Use with new hard lines from the auto parts store ~ $80 ~ IN STOCK NOW
MAX stainless steel braided lines and fittings kit for in line Master Cylinder ~ Allows easy installation in the OEM brake system ~ Stainless lines have a clear sleeve to prevent abrasions ~ all fittings are included that are needed to splice HB cylinder into a singe M10 1.0 thread rear brake line ~ Only $70 ~ IN STOCK 3-2012
lines are available from earls now if you are in some hurry so you can order your hand brake now, and order earls separately or order the brake now, and place separate order for lines which would guarantee you get the color you want while its in stock
the point of the rear mounted version on the side of the tranny tunnel is so that the master cylinder is not hitting your knee.
tranny reinforcement metal & lines and fittings kits arrived for in line master type hand brakes.
Its mandatory to reinforce your tranny, dont just weld directly to it! If your fabricator has some spare 1/8" plate cool, if not buy the raw materials from us for $5
